08-29-2010, 11:13 AM
KY
Too much cam for a 351W...especially to be a hydraulic.
On E7 heads, they don't have rocker studs. It's a pedestal mount rocker arm, unless your set has been converted. The E7 heads were standard heads for factory 5.0 applications.
If you're ready to buy a cam, I'm a Comp dealer and I can pick the correct cam for your application.
You need a piston with somewhere around a 12cc-15cc volume.
