Originally Posted by YerDugliness
Just a quick thought here....does your lower hose have the wire coil inside it to keep it from collapsing? If not, it could collapse and there won't be adequate flow to the engine, the little coolant that does make it will heat rapidly, then surge.......
Cheers from Dugly
No, the lower hose doesn't have a coil in it. Can I tell by looking at it while the car is running if it is collapsing?
Thats an interesting thought.
Thanks.
