I see what your saying and I had the same problem. I used a Hurst Comp Plus shifter with the removable stick. I ended up making a bracket that let me use their stick for a "t-5" shifter and drilled out the holes in the shifter handle (stick) to make it work. I'll see if I have any pics of it. I wanted the "correct" shifter look and it works perfect except I don't have the reverse lock out. I'll see what I got. Thanks, Matt.
