Old 01-10-2002, 06:42 PM
Jack21 Jack21 is offline
Cobra Make, Engine: Classic Roadsters, Tweaked 351W, T-5Z, CRII Tech Support Team.
You can do it either way. I have mine routed along the front of the valve cover, held in place with plastic (nylon) wire holders/standoffs from Summit. Looks neater (MHO) that way. If your headers are ceramic coated, they won't burn your plug wires either way. Using FMS 302/351W set and they fit fine, again either way.
That being said, I had the opportunity to compare the Accel 300+ race wires, and the FMS cores. The Accel cores are substantially fatter than the FMS, look like they'll carry a heavier amperage load, and last longer. Thinking of changing. Not as "Cool" looking as FMS, but my plugs might be happier.
