Thread: Knock-offs
Old 09-03-2010, 02:54 PM
FIA-ERA FIA-ERA is offline
Cobra Make, Engine: ERA FIA 2008/351W/TOP-LOADER
Just as the previous post says. You need a 10lb lead hammer to knock the knock offs with. Yes, they can seize up after time. When installing them back on make sure to use "Anti seize" from Permatex or something similar. I applied it to the drive pins, the mating surface on the hubs/ wheels and the mating surface of the knock offs! Don't get that stuff on you, it gets everywhere! You have to smack them pretty hard to loosen and tighten. Then make sure to saftey wire them back on! Look up posts here on how to do that! Once you do it once you'll be fine.
