Old 09-04-2010, 06:31 AM
DAVID GAGNARD's Avatar
I've only had to remove the valve springs on a few occasions on a head still on an engine, I've used compressed air,mainly cause I have a large air compressor and the adapter to screw in the spark plug hole, so far, it has worked fine....
I'm sure the rope trick will work as good, flip a coin as to which one to use........
David
DAVID GAGNARD
