Old 09-04-2010, 01:56 PM
madmaxx madmaxx is offline
I tried the rope trick, by the time you fiddle fart with trying to turn engine over to compress rope against valves you would be done with one cylinder with a comrpessor. For kicks you will get the rope pinched in a valve then when you are done and you go to pull the rope, it aint comming. You might want to take to mechanic and let them do it.
