Old 09-04-2010, 04:10 PM
Hotfingrs's Avatar
Hotfingrs Hotfingrs is offline
Cobra Make, Engine: EM cobra, 450 inch sbc running a best ET of 9.14..so far..ALL MOTOR...approx 800 horse.............ERA with 482 FE..All Aluminum Engine
Send a message via Yahoo to Hotfingrs
I've never used compressed air, I just run the cylinder I,m working on to TDC and take the springs off. If the valve does slip, it's only going .100 or so down. When you put the spring back on, pull the valve back up, usually it will stay long enough to get the spring on. If it doesn't put a little grease on the vavle stem, this will hold the valve until you get the spring back on.
Jack
XSSIVE .....
