See other post thread too
Xavier Forgot to ask, What size cable goes from the ALT output to the starter soleniod or battery direct?? You also need a 4awg with a 125-150 amp mega fuse in the curcuit. Your wiring is not big enough and causing charging problem. 10 & 8 are not big enough for 100 amp setup. If the wires are real hot, the system is under size. Try paperformance and get one of there wiring kits for alt output. There about 25-40 dollars depending on length of cable. Rick L.
