Old 09-05-2010, 11:24 AM
blykins blykins is offline
Yes, same camshaft.
The heads (at 200 cfm) would be head and shoulders over the E7 heads. A basic rule of thumb is that you can get about 2hp/cfm if the rest of the engine combination is "right". So with a 200cfm intake flow, you could see around 400hp if the compression and camshaft were right.
Those heads would of course work with 393ci. However, I don't think you'd see much of a horsepower increase over the 351 cubes. You would see a lot of difference in torque, which is what you feel.
Never pass up cubes if the price is right. It would give you a better foundation for future improvements later on.
The 3.85" stroke is nice because you can still use a factory 351W rod and you can use a 302 piston.
If you go with the 393, the camshaft would need to be bumped up to deal with the extra volume.
Lykins Motorsports, LLC
www.lykinsmotorsports.com
www.customfordcams.com
brent@lykinsmotorsports.com
