If I remember correctly, the factory beefed up the design at around #1670. Cars made after that are still subject to some sheer BUT they used heavier bolts and welded sleeves into the chassis hole to minimize the stress. If you have a car above 1670, the bolts should continue to be monitored and treated as a regular maintenance item. Lower car numbers should DEFINITELY buy the upgraded mounts and put the issue to rest. As for me, even if I had one of the later cars, I would invest a couple of hundred bucks in the upgrade and eliminate any concern. As much as we dump into "fun stuff", it makes at least as much sense to invest in safety.
Uncle Fester - Yes I REALLY did say that
