Egg shell!!!!!
If you drive it like there are egg shells between you and the throttle you might be ok. Any abrupt moves either on or off the gas could get interesting. Depending on the stall speed of the converter and the valve body your shifts could be abrupt and brake traction at the worst time!!! I suggest that you join up with a auto cross group and practice running the cones. There is a thread that says "IF YOU TAKE ME FOR GRANTED I WILL KILL YOU" and I think you should repeat that line every time you put the key in the start position.
Cheers Greg
