Cheap and easy thing to do first is an
oil change, go back to the
oil you were using before switching to Mobil 1 and put some miles on it, it could be part of the problem, but I doubt it, but it's an easy,inexpensive thing to check before pulling the engine apart.....
Yes, you can check/change valve seals without pulling the heads, not hard to do.........
David
