Old 09-14-2010, 07:39 PM
DAVID GAGNARD's Avatar
One easy way to check for electrical/plug/wire problems is to wait until dark and open the hood and start up the car and let it run, then go look closely under the hood at the wire/wiring for the tell tale little blue arcs of electricity, dead give-away something is grounding out..........
If you have a plug wire that is grounding onto something it will show up immediatley.........
David
DAVID GAGNARD
