Old 09-14-2010, 08:40 PM
twobjshelbys's Avatar
twobjshelbys twobjshelbys is offline
Do not put the spinner back on without anti-seize on the nut and on the flat spinner to wheel mating surface. Oxidation will build up on that flat surface. The anti-seize will make it easier to remove. After two or three of them you will recognize the "ting" sound. Sounds like a bell. Use the safety wire. My wheels are painted yellow so I bought some yellow insulated wire, removed the wire and inserted the safety wire through the insulation. The insulation will help the wire from rubbing the finish off the wheel. The color matches very well, so it looks right.
