  #28 (permalink)
Old 09-16-2010, 01:30 PM
kitcarbp's Avatar
kitcarbp kitcarbp is offline
Cobra Make, Engine: West Coast, 460 Ford Racing Crate w/ TREMEC TKO 600
Default Try a 351 Cleveland Water Outlet to clear distributor ?
Jeri, Have you investigated using the 351C thermostat housing, it has a lower "profile" and may clear your distributor ? Same flange and bolt pattern but I have not tried this personally. You would need a molded 90 degree elbow hose to come off the 351C housing which is a vertical outlet, but a 90 deg. elbow is easy to find at a local parts store in 1.5".
"...some assembly required, ages 8 and up...... well that took longer than expected......
