Old 09-16-2010, 04:27 PM
scottj scottj is offline
Cobra Make, Engine: Everett-Morrison, 434 cid
Originally Posted by BBfangs View Post
Scott,
I have a question about the C4 suspension. I have Carrera coilovers and if I tighten up my adjustments the springs rub the half shaft on the passenger side. Sometimes I think vibration tightens it because I have a mark around the half shaft on the passenger side where I can see it rubs. Can this be rectified? Or is something wrong?
I had the same problem with my Proshocks. Since I have adjustable trailing arms I made a small compensation in the lengths of the arms. I corrected the problem by switching to a small body damper and spring. I now have plenty of clearance.
