  #29 (permalink)
Old 09-17-2010, 09:07 AM
392cobra's Avatar
392cobra 392cobra is offline
6th Generation Texan
Originally Posted by Excaliber View Post
Just thinking out loud,,, I would suspect the amperage to go up with a longer rather than a shorter battery cable. Not to mention a good or great ground strap path.
You say you have a bad history with batteries & cables ?
Here you go Ernie.....
To make a current flow through a resistance there must be a voltage across that resistance. Ohm's Law shows the relationship between the voltage (V), current (I) and resistance (R). It can be written in three ways:
V = I × R or
I = V/R
or
R = V/I
where:
V = voltage in volts (V)
I = current in amps (A)
R = resistance in ohms (R)
or:
I = current in milliamps (mA)
R = resistance in kilohms (k)
