Old 09-17-2010, 03:17 PM
Mark Thompson Mark Thompson is offline
Cobra Make, Engine: Kirkham #625 427S/C, 468 ci Al block, 615 HP
The switch can rub on the back of the steering wheel; sounds like yours is. Mine did too as delivered If you loosen the set screw on top you can slide the switch away from the back of the wheel and eliminate the contact.
I guess I will have to play with the switch now and see if I can activate the self canceling.
Mark
