Old 09-17-2010, 08:27 PM
mickmate's Avatar
mickmate mickmate is offline
There's a phillips screw that locks the switch assembly to the column. If you loosen the screw it will adjust around and in and out a little to get the clearance you need off the wheel hub. If you pull the steering wheel off there is a screw or bump of some kind sticking out of the steering shaft. It will be centred on the cams that come out when you put the switch on.
mickmate
http://www.actoncustom.com/
