Old 09-18-2010, 04:43 AM
pusherfans pusherfans is offline
There's a phillips screw that locks the switch assembly to the column. If you loosen the screw it will adjust around and in and out a little to get the clearance you need off the wheel hub. If you pull the steering wheel off there is a screw or bump of some kind sticking out of the steering shaft. It will be centred on the cams that come out when you put the switch on.
cool, I'll check it out thanks!
