Originally Posted by Rick Parker
Remove the gear and shaft, bead blast advance mechanism parts, consider replacing the bushings as needed (real easy) and reassemble. You'll never be satisfied with the finished product unless you disassemble it before attempting to clean it.
So the weights and bottom half of the advance mech aren't going to come out unless I remove the shaft? Also, given that I don't have a bead blaster, any other suggestions to remove the surface rust (other than soaking them and using a wire brush, which I is what I'm doing).
Do you know the exact bushings and where I can buy them?
Lastly, do I need any special hi-temp grease when I reassemble, or will garden variety automotive grease work fine?
www.partskeeper.com
