Old 01-12-2002, 08:00 AM
Mohuska Mohuska is offline
I feel the need for speed
Default Suspension
Venom..Thanks for the reply. The WC Cobra uses a MII suspension. I don't know what was done to lower the suspension...I believe they used shorter springs. The car is heavy..weighing in at about 3600 lbs w/ engine. The ratio is claimed to be 50/50 weight distribution. The engine is a bored out 460..Cobra jet heads and Holley 950 DP...Claimed to develop 600 HP.....
Rear is a Ford 9" solid-28 spline. Front and rear systems have a heavy coil with shock mounted through the middle....not a true coilover though...I am trying to get this car up enough not to scrape all the time and keep CG low enough to improve lateral stability
I would appreciate any help from you or anyone else...Thanks
