Thanks very much for the suggestions. I ground down a box end to fit and it simply broke the wrench because I had to grind off so much to fit.
I'll try the crows foot and if that doesn't work I'll try to chase down a Snap On truck.
Vice grips? I'll see... thanks for the ideas tom
These are the new ones I used on the passenger side. I had to grind down the tab to fit between the header pipe and the bolt , but they're on.
http://www.stage8.com/ford.html
