Originally Posted by Wbulk
I do want to present the other argument for using the 15L slot for 30 deg. of mechanical. That is the issue of easier starting, since initial timing would only be 6-10 deg. it may be easier to start. Generally, engines are harder starting with a lot of initial advance.
Although with that little amount of base timing, how's that doing to affect my manifold vacuum, which is only about 10" with way more timing than that.
www.partskeeper.com
