  #22 (permalink)
Old 09-25-2010, 08:50 PM
dcdoug's Avatar
dcdoug dcdoug is offline
Originally Posted by Wbulk View Post
Do you have a vacuum advance distributor or was it modified so the vacuum advance was removed? If it was removed the points mounting plate needs to be secured so it does not rotate/shift. If that rotates the advance changes. Just a thought.
Wayne
Mech advance only. Never had vacuum. The points have been replaced with a Pertronix ignitor, which is on it's own secured replacement plate.
www.partskeeper.com
