Old 09-29-2010, 03:58 PM
azfordman's Avatar
azfordman azfordman is offline
Cobra Make, Engine: CCX-3-3624, 351w, 5-speed
I would like to test the tach before I send it off for repair/replacement to verify if the problem is the tach or wiring on the car. On the back of the unit there is a cluster of three spade connectors, +VE, -VE, and Trigger, there is also a 4th spade connector attached to the housing itself, another ground??? If I rig it up in the engine bay to test it how should I do it? The power + and - seem pretty straight forward, but where should I get the signal from? It is a stock ford pointless ignition system. Do I get signal directly off of the coil (if so, which side) or out of the ignition box? Thanks!
"Freedom is only an illusion when the government has all the guns."
