The PCV valve has to be vetical in order to work. They have a check valve in them to allow pressure out but nothing back in. If you mount it sideways then the ball will just float allowing air to travel both ways. To chack a PCV valve you shake it back ond forth to make sure the ball moves and is not stuck.
With that being said, alot of guys dont run a PCV valve..they just run a breather. If you have some good baffleing to keep the
oil mist to a minimum just run the hose from the crank case to atmosphere with a filter on the end of it, if you can get away with that where you live.
