If it was me, I'd go with a Ford Racing universal set in black. Buy a good set of crimping pliers and make them up yourself. It's easy - you cut each wire to length (one end is already on), slide a boot on, fold the conductor back over the end and crimp the connector on. Slide the boot down over the connector, and you're done. Repeat 7 more times.
The 8mm+ wires are too large for the factory valve cover wire holder thingys, so you will need to buy a set of Moroso or some other brand wire separators, drill a couple of holes in them, and rivet or bolt them to the valve cover tabs.
Summit has good Ford Racing prices, and quick, free shipping.
CSX4068, '69 Bronco, '70 BOSS 302, '87 Mustang GT, '08 Roush Trak Pak
