Originally Posted by Rare Iron
You could run ones with 2.5" cores & they won't kill your engine, but you are def in the 3" flowpath size requirement! 2.5's with packing will control noise better than the 3" Cobrapacks. Keep in mind, a LOT of high HP Cobras are running around through the "stock" mufflers which have under a 2" flowpath! ABSURD!
-Eric
Hi Eric!
Are the 2,5 packed really a lot quiter then the stock Superformance?
Do you sell complete sidepipes too?
Mine is runing on stock mufflers and the old Superformance headers which have a small port (to small for the heads) But it can not be so bad because the engine have 542 at the flywheel and 450 at the rear wheels. Of course there are allways possibilitys to get more hp...but i am not sure if it really makes a difference if you have 20hp more.
Peter
