I wonder if this swaybar upgrade would be overkill for the novice SPF driver -- maybe a good upgrade after you are comfortable in your own skin, and in concert with a good alignment shop.
-- this way you can take advantage of the bar'(s) and not chew a hole in your Avons, or your wallet. -- bars by themselves do not usually alter tire angles, but it is not a bad idea to have the alignment checked out whenever you do a mod.
