All the things mentioned can be the root of your starting problem. I had the very same problem with my 418W and was solved with a Ford Hi-Perf starter. I ditched the stock starter and have had no starting issues for 7 years now. My engine ground wire from frame to bellhousing bolt came loose years ago causing a no/hard start condition. Cleaned and tightened work done by a mechanic earlier in the week.
