Old 10-04-2010, 05:04 AM
Caprimaniac's Avatar
Caprimaniac Caprimaniac is offline
Cobra Make, Engine: Unfortunataly ; none
Thank you all so far. 650 & a "more ram" intake it will be. I will have to check heigth of the components. But maybe someone can give me a guildine here. Have 48 IDF on Inglese manifold + K&N filters (oval type). Will 4- barrel + Vic jr. w/ low profile air cleaner be of the same height? I think I measured current setup as 10" high from base of manifold to top of cleaners.
So, AFR's will do the 347 something good? Hmm. I will look closer. But exactly what will they do?
- 205 AFR's 291 VS 296 cfm @ 0,6 lift, a little more difference at the exhaust...
- 60 VS 58 cc chabers Makes compression 10.8 instead of 10.5
- Both designs have raised exhaust ports.
I don't know. The Vic jr's should take it to 500+ Hp. Is there really alot to gain?
rS
