10-04-2010, 05:09 AM
KY
A Victor Jr. intake is 5.5" tall by itself, so you'll be up over the 10" by a bit.
I wouldn't pay much attention to advertised flow numbers; they can be tricky to sort through sometimes...plus most of the heads never flow what the manufacturer says they do. The AFR 205's would probably be 20cfm over the Victor Jr's. Also, peak flow numbers aren't everything....the average flow numbers (low and mid lift performance) means a lot too. Adding more cfm while keeping the CSA the same or lower makes for a good performing head.
