  #51 (permalink)
Old 10-04-2010, 11:14 AM
Voyager's Avatar
Voyager Voyager is offline
Cobra Make, Engine: SPF #2920 w/ Keith Craft 408
Not freaken fixed at all. My goal for next weekend is:
Pull the current thermostat, test it in a pot of water, drill a hole in it and put it back in. Also picked up a balanced thermostat as a backup.
Will also install a bypass hose. Any idea what size hose fitting I will need to screw into the Edelbrock 351W based water pump? Trying to make only 1 run to the store.
The sensor is on a short extension on the intake. I like the idea that it may be getting a steam pocket built up under the tip. But we had temp fluctuations before the dealer installed the extension. But I do think I will take the extension out anyway.
Bob
