10-04-2010, 10:49 PM
GA
Cobra Make, Engine: Butler Cobra. 350 Chevy Engine, blueprinted, heads cc'd, ported, polished, manifolds matched, big valves, 1.6 roller rockers, TB Injected, mild cam, MSD crank trigger electronic ignition. TKO-600 transmission. XKE Jaguar rear. IFS by Fast Cars
The other nice feature is that the pedal box is adjustable from front to back. If you examine the photo you will see extra holes for this purpose.
I've got mine in the full front position like Russ. I've drilled extra holes on mine to make small incremental adjustments should I need to.
Arthur
Reason: more verbiage.
