Old 10-05-2010, 03:56 PM
Positraktion's Avatar
Positraktion Positraktion is offline
Cobra Make, Engine: FFR MKII, warmed over 5.0, Turned 30,000 miles on January 1st run
Just a couple thoughts here...I am a GREAT believer in process of elimination by simpliest methods first.
1-My Sunbeam Tiger used to do exactly what you are saying, it was due to vapor lock. But as I said, do the easy stuff first.
2-Check vacuum at idle normal temperature and then when it heats up. Get it hot so that it does stumble and see what the vacuum is.
3- Throw a timing light on her when she is at idle normal temp and then again when she is stumbling hot.
One of these tests should tell you what she is doing.
Keep us updated......Posi.....
