Old 10-06-2010, 03:03 AM
boxhead's Avatar
boxhead boxhead is offline
Default Ideal front and rear suspension setup
If you where building a Cobra purely for circuit racing with the occasional drag weekend thrown in, what design would you use?
Front end I guess idealy would be uneven length upper and lower control arms, with front and rear upper and lower rose joint inner control arm mounts, U shapped arms (so no caster bar is required)?
Is there a site somewhere that allows you to play with designs so you can see what camber/caster changes occure with suspension travel?
For rear end, would IRS be best or a watts link type setup on a solid axle?
Thanks for any links or ideas.
Cruising in 5th
