Originally Posted by azfordman
The manifold vacuum seems to be consistent, so I don't think it is a vacuum leak. This leads me to the possibility of the fuel pump causing issues when it gets hot. Considering the crap oxygenated fuel we have here in Southern AZ, I am considering going to an electric fuel pump to eliminate possible vapor lock issues. My question is, do I have to run a return line to the fuel tank or can I just install the pump and be good to go.
Youll have to run some sort of a regulator if you dont have one already. Most electric pumps will push way more than the needle and seats will hold.
Something else to consider. Try backing your idle screws out just a little to give it alittle more fuel at idle. Your strictly on the idle circuits at idle obviously and if you set them when the motor was cold they may not be rich enough. Back them out a 1/2 turn and see that that does.
Just a thought.
" If it wont break em loose in 3rd gear, it aint enough power "
Reason: cant type or spell....lol
