Old 10-07-2010, 04:03 PM
Z-linkCobra's Avatar
Z-linkCobra Z-linkCobra is offline
Cobra Make, Engine: Everett Morrison, All aluminum small block ford.
Unless you buy a pump that specifies that you must run a return line....dont need one. Holley blue or red will work just fine for what you need and all you will need is a regulator.
The Holley pumps are designed and built to be pushers not pullers. Mount the pump as far back in the car as you can get it. Splice the line and put the pump in. Take your fule pump off the motor and get you a block off plate. you can use the split in the lines where the stock pump was to put you in a regulator..Holley makes a real simple one as well. One line in 2 lines out one to each bowl if you want. If your running a fuel log then you can run it one line out and just plug the other ooutlet of the regulator.
What kind of carb are you running?
" If it wont break em loose in 3rd gear, it aint enough power "
