Originally Posted by Butlers24rth
Craig,
One problem that I have had at 6'-2" is that the gas pedal is the limiting factor as it hits the fire wall. I was going to swith to a cable system as the linkage type does not get the travel I need. I have also put the seat on the fllor with its back against the read of the seating area. This gave me a lot more room.
Scott
Scott, I do not know how much modification it will take to install a cable system and will it offer you ratio modification to achieve the travel.
If you still have the Butler system, I do and I believe it to be a simple & well engineered piece. Easy alterations can be made to the crank ratios to increase or decrease pedal travel.
I've modified my ratios to reduce the amount of pedal travel. You can also install cranks that have sliding pivots to change the ratio indefinately.
Arthur
