Originally Posted by azfordman
I think I am going to install an electric fuel pump to see if that makes a difference....I know I have talked to others who have had issues with the gas down here. Of course that is going to have to wait.....pushed the car pretty hard on the Arivaca run yesterday and busted the push rod on the intake valve of cylinder #2..... Looks like several of the push rods are wearing on the guides....not sure if it is the adjustment or if the guy who put the engine together used low grade rods. Will be picking up a set of hardened push rods in the next day or so.
After you install those hardened push rods then youll find the other weak link in your valve train. Sometimes bending a push rod is a clear sign of something else wrong. Even with wear from the guides I would still look for another problem before you put those hardened rods in there.
just a thought.
