Thread: Starter info
Old 10-11-2010, 09:32 AM
RET_COP's Avatar
RET_COP RET_COP is offline
Cobra Make, Engine: Fordstroker 408w custom solid roller-Craft ported Brodix 17*heads-CFM ported Vic Jr. intake-1 3/4 primaries- 575hp-TKO-600RR Liberty upgrade- -Moser 8.8 trutrac-McLeod Street Extreme--QA-1-Wilwood brakes, Classic Chambered 3" Cobrapacks, Avon's
I just spoke to Red Roberts from McLeod. He said the 810156 is universal. It comes with a 3/8 spacer so it will work on both 157 and 164, and if you loosen the nose and rotate it about 30 degrees it will fit a 429. The solenoid can be rotated around the starter for interferences. Jumper wire included for relays on the firewall.
Sounds like a good starter.
Lou
Lou
