Panavia has this one correct. The PCV port is on some carbs, not on others. True race carbs won't have one because its not important for a true race application. Most all street carbs will have one. You should have one.
Not hard to drill and tap a passage for intakes lacking same - be sure to hit both sides of a dual plane to avoid noise caused by runner pulse imbalance. An individual runner is a crummy place for a vacuum tap.
Patrick is a very sharp cat and will know what you need. I use Quick Fuel often because the co-founder and owner is a long time personal friend from the days when we both worked at Holley. I'd tell stories about the night before my wedding...but the statuate of limitations has not run out...
Survival Motorsports
"I can do that....."
Engine Masters Challenge Entries
91 octane - single 4bbl - mufflers
2008 - 429 cid FE HR - 675HP
2007 - 429 cid FE MR - 659HP
2006 - 434 cid FE MR - 678HP
2005 - 505 cid FE MR - 752HP
