Old 10-14-2010, 08:25 PM
Machiavelli Machiavelli is offline
Default Hub Boss Outer Diameter?
Hi Gang,
I need some help! I'm having Schott Wheels make up some custom "Sprocket" rims for me, and it turns out that they can make them hub centric if I can get the outer diameter of the hub bosses defined (or measured). This would be a caliper measurement as the accuracy needs to be within ~.002" of the actual diameter for a good hub centric fit.
Anyone here happen to know what the outer boss diameters are on a JBL Competition Roadster? Thought I would give it a shot, just trying to do everything right on this build, some of it above and beyond the standard JBL details. If I had a part number I would look it up, this appears to be a custom item Larry has built - the parts list says "JBL Billet Rotor Hats-Front/Rear", and that's where the hub bosses are milled in. Anyway, thanks for any info. you can provide, I'm hoping I can nail this one down.
Best Regards,
Machiavelli
