Originally Posted by onefastmustang
So last weekend I decided it was the perfect day to cruise through Napa. Somewhere along the way the pin bolts on my vintage wheels on the rear decided to come loose. I almost lost a rear wheel if it wasn't for an observant follower. I pulled over and jacked the car up and was able to tighten them up and get it home. I know for a fact I had torqued the pins down to 70 ft-lbs. What other options do I have to prevent the pins from coming loose on my adapter bolts and this happening again??
TIA
Mike
I've never heard of that happening before. There might be something else going on there. You sure the mating surfaces are clean and no obstructions that would prevent the adapter to seat fully on the rotor face? Check that the center of the adapter is clearing the center of the axle or spindle hub as well.
