  #24 (permalink)
Old 10-18-2010, 11:36 AM
wanab5150's Avatar
wanab5150 wanab5150 is offline
Cobra Make, Engine: Superformance #2769 Roush 427R Dart Block
After I did the header bolts I went over the engine and chassis in search of loose bolts and nuts. I have tightened the header to muffler flange bolts numerous times assuming they kept coming loose.
I replaced the grade 2 bolts (which were used by the installer) with grade 8 bolts after removing them and finding they were stretched and bent from the constant tightening over the last 3 years.
There's a lot of vibration and movement at that connection so we'll see if the higher grade hardware will do the trick. I was luck they never blew the gaskets out.
Tom
I miss my Tazer
