Old 10-19-2010, 02:35 PM
Richard Hudgins's Avatar
Richard Hudgins Richard Hudgins is offline
Cobra Make, Engine: Porsche 928 S4
Machiavelli,
I am not in any way suggesting that you do not use the 18 inch wheels.
There is a much better selection of tyres available in 18 inch.
I just need to know the sidewall construction in order to give Larry the spring rates and damper curves.
But this as I stated may be of very little import as the 17>18 inch tyre spring rate may be so close that nothing needs to be done. (If it does need to changed it is not at all a big deal, I just spec the bits to Larry and he puts them on the chassis.)
Stick with the 18's.
Best regards,
Richard Hudgins
