Maybe you could remove the slave cylinder rod to allow the spring to pull the fork as far forward as possible. Then if it moves forward enough you could get in there with a small cable drive Dremel attachment & grind the end of the fork the required amount.
With the fork in place you would be able to move it by hand back into position & check for clearance.
Craig
