Pulled the motor mounts last night. Put the car on jack stands and used a jack under the pan to raise the engine an inch or so.
As for the
oil leak…the AN fittings were tight, but the
oil filter adapter plate was loose. Snugged it into the block. I cleaned the
oil residue from the frame and components while my 17-year old son modified and installed the Olthoff mounts. Lowered the engine back down and discovered that we’ll need to do some shimming to get everything lined up. By then, my kitchen pass had expired.
BTW – just for grins, I threw the old thermostat in a pan of water and it slowly began opening at 180ish. Was fully open around 10-15 seconds later. Seemed very sluggish, but I didn’t have time to experiment with it.
And yes - I stared at the temp gauge the entire test drive. It will take a while.
Bob
